Winch questions.
DTR 1st Sergeant
Also, the Ruenel factory was only 40miles from my house at the time so I got to see the operation and talk to them face to face. Basically, it was a deal where they made their stuff compatible with Warn, so if you used something else and didn't like the fit, they could disclaim it.
Update
I installed a 12,000 pound Mile Marker hydraulic winch. Have not used it very much yet, but so far it is working great. Last week I used it for some very heavy loads (winching out complete trees) and even after over 30 minutes of continuous use it was still going strong. An electric winch just would not do this.
The only problem I had was the the plug for the remote fell apart after the first use and the rubber plug MM supplies for this was too small and kept on falling out. I cut the whole thing off and used a male/female trailer plug and that works just fine.
Update
The cheap electric winches are as slow as any other brands cheap electric winch. 5 ft under load and 20 ft no load.
The hydraulic winches are 2 speed, slow for winching around 5 ft. per minute and high for cable retrievel, around 50 ft per minute. You can't winch on high speed.
Hydraulics are great, but you won't find me running one that needs the engine to be running. I have had to use my winch before when the engine wont start. My truck would have been stranded with a hydraulic, but with the electric it got us back to spare parts.
I don't understand the value of high cable speed in winches, when I am recovering slow and low is Ok with me. Fast is not good, things can go wrong too quickly.
It was really not far between "stranded" and "rescued" I guess if it was within the reach of an electric winch pull... what is that, 10 feet? Once the electric is done, can't start the engine either, batteries are flat.
10 feet? I have over 125' of rope on my electric winch, thats a lot to pull, and I have never needed to pull that far.
On my current truck my winch is in a basket, so now I can move it front or rear and use it. Something not as easy on a hydraulic.
i like the idea of running a hydro winch on my truck as all my warn atv winches have never been "big" enough for the emergencies ive been in. I have thought about how i would attach it to the rear if i wanted something i could move around. How about running hoses to the back and getting quick connections just like a tractor. I dont know if this will work but its an idea. would be heavy though.
Sure! they make quick connects.
Hydro is heavy duty better for extended pulls and electric is light duty better for short pulls.
Hydro is slow and good for long hard pulls with no surprises.
Electric is better for offroading. Usually just need a quick 1-10' pull off a rock or log and you want a fast line speed to get the group moving again quickly.
Its great if the line speed is faster than low range you can just idle in low and let the winch wind in fast and tight.
I on the other hand am in the middle of setting up a MM hydraulic under the truck, non-removable and will post pictures and a report once I am finished.
fade94
05-04-2010 10:39 PM
phox_mulder
05-29-2004 10:19 AM
