Off Road / 4x4 OffRoad discussion, along with 4x4 events and information.
Vibration
Old Dec 7, 2005 | 01:15 PM
trey1115's Avatar
Vibration
I have a 1998 Dodge with a 7" Skyjacker Lift, after the lift was installed, I noticed a vibration in the steering wheel, it is only present when I am sitting still, and I can move the steering wheel a slight bit and it will stop. Any Ideas?
Thank you,
Old Dec 19, 2005 | 05:50 PM
apache's Avatar
Im not familiar with lifting rams but with 7" I wonder if your front drive line is starting to bind or? you just now can feel it thru the wheel. Typically the angle the 2 yokes needs to be no more than 1.5 degrees difference if not less. dunno, just something to look at.
Old Dec 20, 2005 | 02:16 PM
CTD NUT's Avatar
Thank you,
Was a body lift installed also? It could be possible that the steering column is getting slighty stressed from an over extended steering shaft which may limit the ability of the vibration damper to work properly.
Old Jan 6, 2006 | 11:47 AM
Cowhand's Avatar
My first suggestion would be to get rid of all that red garbage you put on your poor truck, but seein' as how you've spent all the money and effort already.....
Check the intermediate shaft between the box and column. They get sloppy and it will transmit idle vibration through the column to the wheel.
dodgedsl03
Jan 18, 2007 10:08 PM
Davidp
Mar 19, 2003 11:29 PM
spitzair
Mar 11, 2003 11:06 PM
deere nut
Dec 1, 2002 08:09 AM
chdiesel
Nov 3, 2002 04:39 PM
