-   Off Road / 4x4 (https://www.dieseltruckresource.com/forums/off-road-4x4-111/)
-   -   Rim question (https://www.dieseltruckresource.com/forums/off-road-4x4-111/rim-question-93339/)
Ian Feb 22, 2006 08:00 PM
Rim question
what exactly is backspacing? alot of people talk about it, but I don't know what it is...what a newbie question... [laugh]
phox_mulder Feb 22, 2006 08:33 PM
Measurement from the inside mounting surface of the rim to the inside edge.
Stock rims are around 6.25 inches,
most aftermarket are 4.5 inches.
phox
Ian Feb 23, 2006 08:15 PM
ahhh...i see, i see...and the less back spacing, the more the rim and tire will stick out past the side of the vehicle?
derek840378 Mar 1, 2006 02:28 AM
correct ;)
slorocco Mar 1, 2006 09:41 AM
Just in case you're interested: The alternate measurement that's used by some wheel manufacturers is Offset. This is a measurment of how far the wheel mounting surface is offset from the centerline of the wheel, specified as positive or negative offset depending on if it's offset to the outside or inside.
