-   Off Road / 4x4 (https://www.dieseltruckresource.com/forums/off-road-4x4-111/)
-   -   Rear block question (https://www.dieseltruckresource.com/forums/off-road-4x4-111/rear-block-question-221850/)
pickupman96 Oct 30, 2008 08:32 PM
Rear block question
Well I put in my 5 inch superlift and I see a problem. The rear they only sent a add-a-leaf. With it on the ground the rear is about 3 inches low. Should it have come with a block for it or can I put a block in on top of the stock block. Thanks for the help
bob4x4 Oct 30, 2008 10:04 PM
Never stack blocks..........go with a correctly arched spring instead
DNRCustoms Oct 30, 2008 10:17 PM
x2 on that
pickupman96 Nov 5, 2008 04:13 PM
where can I get a 6 inch lift spring or get a larger stock block. I cant stand it anymore looking like this and I cant get shocks until I get the ride height correct. thanks for the help
pickupman96 Nov 6, 2008 01:21 PM
anyone????
Captain Nov 10, 2008 09:25 AM
I hate "leveling lifts" when I put my skyjacker on with full leaf packs I had to up the rear end as well. One of the things I did besides putting in extra leaf springs was to put a block on the factory block. Here is how I feel is the only safe way to do it. I got blocks from BDS that bolts to the leaf package and then of course longer center bolts. I got those from atlas. Then I took the leaf package apart. added the springs I wanted to and bolted it all together including the new block on the bottom of the package. Then its all locked together as one unit and the head of the bolt sticks out the bottom to locate into the center of the factory block.
