Off Road / 4x4 OffRoad discussion, along with 4x4 events and information.
Bead locks????
Old 10-28-2007, 03:54 PM
dieselcarpenter's Avatar
Question Bead locks????
I have never run or messed with bead locks,but I do know how they work. My question is, the ones I see on TV only seem to lock the outer bead. I saw a set one time that had an inner bushing to lock the inner bead but only once. What good is only locking the outer bead? Unless I am stupid and never noticed them locking both??????????
Old 10-29-2007, 01:21 AM
Honkylips's Avatar
While inner beads will unseat at times, it's pretty unusual. It's usually the outer bead that unseats.
Old 10-29-2007, 07:18 AM
BRUISER's Avatar
exactly..
Plus you can get "hummer" beadlock which do lock both outer and inner beads.. the rims are a 2 piece design with a magnesium or plastic inner piece that holds the beads together.
there are also a few companies that do make outer and inner bolt on beadlocks.. but you have to get a bigger rim like a 17" to clear brake calipers.
Old 11-03-2007, 05:02 AM
LanceD's Avatar
I have double beadlocks from www.stazworks.com. I love them. although I do wish I would have got 17s
getting the ring into the tire is fun
Old 11-03-2007, 02:17 PM
JKM
JKM's Avatar
Lance , what are a set of rims like that worth?
Old 11-03-2007, 06:43 PM
LanceD's Avatar
they have a price list on their site somewhere, but you can get them in pretty much any size you want. and if you want a custom pattern, say a big Cummins C in the rim all the way around, he can make it.
Old 11-09-2007, 04:59 PM
JKM
JKM's Avatar
sounds pricey... I don't need beaklocks, those rims just look awesome.
Old 11-09-2007, 05:03 PM
JKM
JKM's Avatar
I just looked , they are over 300 bucks a pop for the size i want, i can get non bead lock alloys in that size for a little over 160 a piece...
Old 12-04-2007, 03:46 AM
Are there any double locks that are DOT approved ??
Old 12-04-2007, 09:25 AM
Honkylips's Avatar
http://www.high-impact.net/wheels/do..._beadlocks.htm
Old 01-02-2008, 12:43 PM
LanceD's Avatar
the wheels from the H1 hummers are.
also the ones I got have DOT numbers on them.
Old 01-02-2008, 03:17 PM
crucescrawler's Avatar
Staun makes an internal beadlock system. I have weld on beadlocks on my jeep, but my dads jeep has the staun setup. pretty pricey, but if you trash a wheel, you can pull them out and reuse them on another wheel. They are also DOT approved. Oh, and they on 16.5 wheels, and we both run about 5-6 lbs in the rocks... Something interesting to look into for sure...
Old 01-03-2008, 04:24 AM
LanceD's Avatar
yeah I forgot about those
Old 02-03-2008, 07:54 PM
tristan21's Avatar
Dont forget that they are REAL heavy. At least I think I remember reading that in four wheeler.
Lunds Ram
06-14-2011 08:37 PM
Desert Dually
06-20-2009 10:58 PM
Jmac
15
04-22-2005 02:22 PM
zulusafari
08-26-2004 07:21 PM
glowball
21
05-07-2004 01:16 PM
Quick Reply: Bead locks????
