Extra leaf spring articulation??
Are there any after market DOT approved spring shackles that allow for extra articulation? (for 3/4 and 1 ton trucks) Like the terraflex revolvers for jeeps? Are there any other soloutions? Is grease or penetraing oil/lube a good idea for the spring packs? or does it attract dirt and and cause extra wear? :confused:
I spray my leafs with different kinds of oil after spraying the dirt out of them. usually WD40 or similar.
if you want more articulation, look into doing a shackle flip, getting some lighter leaf packs, or moving the springs inboard a few inches. |
If I go with urethane instead of rubber bushings will this affect articulation?
no
but whatever you go with, make sure you install them with plenty of anti-sieze. |
Why hasnt any body built a shackle like the terra flex revolvers for larger rigs? I think it would be cool to have huge heim joints on the ends!
http://www.teraflex.biz/productImage...%20shackle.jpg |
mostly because they are really unstable in the corners, imagine going around a corner and one of those revolvers unloading, it will shift all the weight over, at least thats what I read why the jeep guys don't like them.
Originally Posted by dieselcarpenter
(Post 1873991)
Yes harder bushings will affect articulation to some extent. Bob |
http://i28.photobucket.com/albums/c2...airbags015.jpg
http://i28.photobucket.com/albums/c2...airbags014.jpg This is how mine articulates,using a Carli Suspension system. Bob |
they also seem pretty cheesely made and they need to be load rated for the vehicle there made for so noone wants the liability of one breaking if someone slams a gooseneck trailer on there truck and a spring hanger snaps slaming them into a short bus filled with lawyers kids
very true.
heres a pic of my flex with 9 inch Atlas leaf springs, 1 inch blocks, shackle flip and belltech "lowering" shackles (which are about 4 inches longer than factory shackles) http://http://memimage.cardomain.net...7_946_full.jpg I think the only way to get a better flex out of leafs than what im getting is to remove some leafs out of the pack, but I would be sacrificing load capacity. or a 4 link and coilovers :cool: |
I see no pic ?
Bob |
bob is that about a 2" lift with 35's do they rub under full compression
Looks like your signature is missing those full lockers?..
Originally Posted by trx
(Post 1892934)
| All times are GMT -5. The time now is 01:22 AM. |
