Off Road / 4x4 OffRoad discussion, along with 4x4 events and information.
Extra leaf spring articulation??
Old Dec 30, 2007 | 04:28 AM
dieselcarpenter's Avatar
Question Extra leaf spring articulation??
Are there any after market DOT approved spring shackles that allow for extra articulation? (for 3/4 and 1 ton trucks) Like the terraflex revolvers for jeeps? Are there any other soloutions? Is grease or penetraing oil/lube a good idea for the spring packs? or does it attract dirt and and cause extra wear?
Old Jan 2, 2008 | 12:40 PM
LanceD's Avatar
I spray my leafs with different kinds of oil after spraying the dirt out of them. usually WD40 or similar.
if you want more articulation, look into doing a shackle flip, getting some lighter leaf packs, or moving the springs inboard a few inches.
Old Jan 5, 2008 | 02:00 AM
If I go with urethane instead of rubber bushings will this affect articulation?
Old Jan 5, 2008 | 07:07 AM
LanceD's Avatar
no
but whatever you go with, make sure you install them with plenty of anti-sieze.
Old Jan 5, 2008 | 08:49 PM
Why hasnt any body built a shackle like the terra flex revolvers for larger rigs? I think it would be cool to have huge heim joints on the ends!
Old Jan 5, 2008 | 10:21 PM
LanceD's Avatar
mostly because they are really unstable in the corners, imagine going around a corner and one of those revolvers unloading, it will shift all the weight over, at least thats what I read why the jeep guys don't like them.
Old Jan 6, 2008 | 01:23 PM
bob4x4's Avatar
Yes harder bushings will affect articulation to some extent.
Bob
Old Jan 6, 2008 | 01:29 PM
bob4x4's Avatar
This is how mine articulates,using a Carli Suspension system.
Bob
Old Jan 7, 2008 | 12:10 AM
dan1stgen's Avatar
they also seem pretty cheesely made and they need to be load rated for the vehicle there made for so noone wants the liability of one breaking if someone slams a gooseneck trailer on there truck and a spring hanger snaps slaming them into a short bus filled with lawyers kids
Old Jan 7, 2008 | 03:36 AM
LanceD's Avatar
very true.
heres a pic of my flex with 9 inch Atlas leaf springs, 1 inch blocks, shackle flip and belltech "lowering" shackles (which are about 4 inches longer than factory shackles)
I think the only way to get a better flex out of leafs than what im getting is to remove some leafs out of the pack, but I would be sacrificing load capacity.
or a 4 link and coilovers
Old Jan 7, 2008 | 08:36 AM
bob4x4's Avatar
I see no pic ?
Bob
Old Jan 15, 2008 | 09:44 PM
trx's Avatar
trx
bob is that about a 2" lift with 35's do they rub under full compression
Old Jan 16, 2008 | 02:37 AM
LanceD's Avatar
try this one
Old Jan 16, 2008 | 04:24 PM
PaulDaisy's Avatar
Looks like your signature is missing those full lockers?..
Old Jan 16, 2008 | 05:32 PM
Pooter's Avatar
3"~ lift and 37s I believe
