Install Aftermarket Tach 1st Gen?
Old Sep 9, 2009 | 09:03 PM
transdamws6's Avatar
What is the most accurate style of a aftermarket tach and where did you get it? for a first gen 12 valve
Old Sep 9, 2009 | 09:34 PM
BC847's Avatar
1st Generation Admin
If your truck is a '91.5 ~ '93, then you have a factory provided plug under the steering column that will give 12vdc power, lights, and tach signal from the ECM.
With that, you can connect directly to an ISSPRO R5503 (0 ~ 4000rpm).
I mounted mine on the column . . .
Here's a write-up I did on my install . . . https://www.dieseltruckresource.com/....html?t=173561
Hope this helps.
Be sure to fill out your "Sig" so folks will know what king of truck you're messing with and be sure to stop in the 1st gen section for help direct from 1st gen owners. https://www.dieseltruckresource.com/...opics-f93.html
Old Sep 10, 2009 | 09:08 PM
Thanks for the reply but no its actually in a 86 chevy i did a swap with a 12 valve? So whats the the best aftermarket way of doing it?
Old Sep 10, 2009 | 09:41 PM
BC847's Avatar
It seems there's those that reference the alternator, or a magnet on the crankshaft damper, or strap to one of the injector lines and feels the pulse of the injection event.
Take your pick. Check with your favorite vendor and see what's available (I've no experience with them ).
If you want, I can move this thread to the 1st gen section for more reply's.
Old Sep 11, 2009 | 07:41 PM
woops my bad I thought I was in the first gen section still gettin used to the site. I have looked into the injector pulse pick up and it wont work, the magnets i don't want to deal with but the altenator is what I was thinking but I have heard the aren't to accurate? Where do you get the altenator pick-up or I think they are an inductive pick-up? Need help?
Old Sep 12, 2009 | 10:23 AM
torqmonster's Avatar
subscribed
Old Sep 12, 2009 | 10:47 AM
Richie O's Avatar
366 Spring Chicken
I put an isspro tach in my 89. I bought the magnet kit that goes on the balencer. Works good and no need to calibrate.
Old Sep 12, 2009 | 02:40 PM
Onemoparnut's Avatar
I also have the isspro with magnetic pick up and it has been great so far for about 2 years.
Old Sep 12, 2009 | 06:09 PM
Jim Lane's Avatar
You can install a mechanical tachometer that runs off the front of the injection pump through the timing case, with the drive adapter you can either use a mechanical head with a flexible cable like your speedometer cable or it can turn a tach generator and connect the tach head electrically.
Or you can install an electric tachometer that connects directly to the alternators stator windings, if you have the stock Nippondenso alternator you will have to add the connection to the alternator but if you install a Leece Neville then it already has them.
This type of tachometer is used on Class-8 tractors and is used on marine applications including diesel powered yachts.
Old Sep 13, 2009 | 01:13 PM
RSWORDS's Avatar
I did the isspro with the magnetic pick-up. Works great!!!
http://www.dieselbombers.com/5-9l-ro...uge-mount.html
Old Sep 14, 2009 | 09:00 PM
Anyone have any websites to get a Isspro magnetic style tach?
Old Sep 14, 2009 | 10:27 PM
peobryant's Avatar
I'd just go to the Isspro website.
www.isspro.com
Old Sep 15, 2009 | 12:41 AM
archer2's Avatar
I've been using the Isspro magnetic one for 13 years now, no problems.
Old Sep 15, 2009 | 08:38 AM
dzl_damon's Avatar
Autometer 2888 (I think) works great, super easy install. Pick up goes around your altenator with a large "hose clamp". Clamp it on, wire up lights, 12v power, and pick up and ground I think and your good to go. There is a zeroing screw on the back to adjust it (I gues the span is already set). I just held it to the floor in neutral on my completely stock truck and tuned it in for 2700rpm. When it came back to idle in park it was 750, put it in drive and it was 700rpm, just like it's supposed to be. You can also dial in your zero with an optical tach, or the type you hold on the pulleys and just compensate for size of pulleys.
Old Sep 15, 2009 | 08:41 PM
awesome thanks for the help think I found the isspro tach I want
