-   HELP! (https://www.dieseltruckresource.com/forums/help-97/)
-   -   VP44 in, now "check engine" & weak power (https://www.dieseltruckresource.com/forums/help-97/vp44-now-check-engine-weak-power-94054/)
joeinblueout4u Feb 28, 2006 05:37 PM
I just finished installing the new VP44. The truck idles fine but goes flat early in the acceration. Also now has a "Check Engine" light. The odometer shows a 0122 and a 1693 code. Did the APPS fry now or does it need to be reset?
Shovelhead Feb 28, 2006 05:46 PM
Double check all electrical connections and grounds first.
joeinblueout4u Feb 28, 2006 06:28 PM
Okay, I'm a big dummy! Left the plug on the top driver's side rear unplugged. I plugged it back in, but the CEL is still on. I'm going back out for a test drive after dinner. I'm guessing the 1693 code was a left over from the VP44. I haven't had the codes cleared yet.
-Joe
joeinblueout4u Feb 28, 2006 08:19 PM
Yeah!!! The truck runs sooo much better with all the sensors plugged in! After a few trips here and there the CEL went away on its own. Thanks so much for all the great info. The whole thing was painless (other than buying the new pump) and took about 4 hours (taking my time.)
piperca Feb 28, 2006 08:46 PM
Hey, Joe, where did you end up getting your pump?
BTW: Hopefully you still got the on-call cha-ching for the court appearance [whistle]
