-   HELP! (https://www.dieseltruckresource.com/forums/help-97/)
-   -   Turn key and engine wont turn over (https://www.dieseltruckresource.com/forums/help-97/turn-key-engine-wont-turn-over-177343/)
stealman1 Nov 9, 2007 10:06 AM
I have a 04.5 Never had any starting problems before. When I turn the key everything works except the starter will not do anything. Im thinking a fuse? Or some other electrical? Im going to go through the fuses right now. Any other common parts to fail in the starting system? I dont want to get it towed.
madhat Nov 9, 2007 10:15 AM
First, make sure that it is in park all the way, or put it in neutral and try to start it. Then, I'd check fuses and wires.
stealman1 Nov 9, 2007 10:31 AM
Thanks madhat
Thanks you made my day The truck was not fully in park. I was close to calling a tow truck and you saved me alot of trouble. Really cool
madhat Nov 9, 2007 11:07 AM
No problem, glad it worked! Start with the easy stuff first... It saves money!
