TST install problem!
Old May 2, 2007 | 11:00 PM
BSILVEIRA's Avatar
Just finished installing the R49 and the install wasn't too bad. I followed the instructions carefully. When I went to start the truck, it ran really rough and had a bad knock. I stopped the truck and put the Power Pup on stock. I restarted and there was less knock and ran a little better. The engine light is on and the water in fuel light is on. No RPMs when running, even if I give it lil bit of pedal. I checked the codes and: P0193 Fuel Rail High, P0341 Camshaft performance, P0340 Camshaft sensor, P0237 Boost low.
Did I screw something up? I used the bypass and it still ran rough. Any ideas?
Old May 3, 2007 | 08:02 AM
04smoker's Avatar
BSILVEIRA, sounds like you may have the cam sensor plug and the crank sensor plug reversed.
Old May 3, 2007 | 09:12 PM
BSILVEIRA's Avatar
I rechecked all the connections and everything was ok, except the white middle wire on the TST rail pressure sensor plug was pulled loose. The yellow rubber seal was out of place. I called TST and they said they're going to send me a new rail pressure harness. Also, I think my remote start is interfering with the TST. Got to put a resistor on the wire. I can't find the wire anywhere and the shop who installed it in '03 said they didn't install my alarm. Crooks! I have a Sidewinder alarm. It's a piece of junk.
Old May 3, 2007 | 09:52 PM
RAT_03's Avatar
DTR's "Secret Agent"
On my 04 i got the code for Rail pressure high so i just backed the rail pressure down and it was fine but when it happen i didnt think it would throw a code you know but dont take my word, just going by what i have seen
mjpalmer
May 19, 2005 11:34 AM
WhiteSport600
Dec 23, 2004 09:59 AM
BCobb
Jul 11, 2004 01:49 PM
Zino
Aug 15, 2003 10:14 PM
