truck wont start after 3200 rpm spring
Old Sep 16, 2009 | 05:32 PM
2wdcumns247's Avatar
finally i have all the right parts in my pump for the 3200rpm spring but it wont start any ideas
Old Sep 16, 2009 | 08:15 PM
Got power to the shutoff solenoid?
Are you sure the throttle lever is indexed correctly? Did you put the full power screw back where you found it?
Old Sep 16, 2009 | 10:07 PM
Im Not Sure What A Shutoff Solenoid Is But I Have Played With The Full Power Screw And It Is Close To Where It Was Before I Believe It Is Very Close To Being Indexed Correctly But Im Not Sure It Should Start Tho I Just Dont Know Why
Old Sep 17, 2009 | 03:19 PM
The shutoff solenoid is the thing near the back of the pump with wires on it. Make sure it has power when the key is turned on.
If you have power there then the problem is your throttle lever indexing, try going a spline tighter.
Old Sep 17, 2009 | 04:33 PM
ok i will try that how do you change the throttle lever indexing
Old Sep 17, 2009 | 05:49 PM
Take the throttle lever off and put it back on one spline tighter.
Old Sep 18, 2009 | 12:36 AM
thanks for the advice it was the shutoff solenoid i finally got my truck tuned today and it made 34psi on the stock turbo we were amazed the egt's were a bit high but a intercooler and a big exhaust will fix that i hit 1650 on my egt gage so kinda high but all is good thanks a bunch
2wdcumns247
Sep 12, 2009 06:30 PM
"B" SCARED
Jun 21, 2008 11:18 PM
HAMMER_DOWN
Nov 14, 2007 04:40 PM
sammy340
Oct 14, 2004 12:28 AM
driverswanted
Mar 13, 2004 04:48 PM
