truck is stranded...
when i turn the key to start her nothing happens... all dash lights come on, but no start. batt cables are tight, i'm wondering if it could be the clutch switch? i did get the starter to engauge but just for a split second... i changed the little battery in my key, gonna try the spare when i get home today. oh and there is no codes. if anyone has any ideas or expirence it would be appreciated. thanks in advance.
There is a fuse for the starter. I cannot remember which one it is but I had tapped into it to connect an aftermarket part on my 03. When I decided to remove that part from my truck I pulled the fusetap out and somehow the connection inside the fuse box had stretched so the fuse was not touching on the one side. I had your exact conditions when this happened. Everything worked but absolutely nothing from the starter. So, I'd be looking there first since it would be the easiest fix... I think it was # 40 or 42 but I may be wrong....
Ben
Sep 26, 2005 12:50 PM
