Tranny problem????
Old Mar 7, 2004 | 09:03 PM
sgrooms's Avatar
Tranny problem????
A friend of mine has a 96 12v with about 165k on it.
He was on his way to Nebraska this morning, pulled over with his trailor to check the license plate on the back, and the truck refused to move after he got back into it.
Supposedly, he bought this truck with a rebuilt automatic tranny. My question is this: Before he pulls this tranny out and looks for a rebuild, is there anything else that might be wrong with this?
After he unhooked the trailor, he got about 5-10 mph running about 2000 rpm. Any ideas?????????
Old Mar 7, 2004 | 09:44 PM
Stamey's Avatar
Has he tried running it through all of the gears? It sounds like something hung in the valve body. May not fix it, but worth a try.
Chris
Old Mar 7, 2004 | 09:51 PM
sgrooms's Avatar
As far as I know, he did...but I will talk to him and see.
Old Mar 7, 2004 | 10:19 PM
phox_mulder's Avatar
Gotta ask the obvious.
Did he check the fluid level?
Cooler lines have been known to let go and leave all the fluid back on the road.
How about the linkage, is it all still linked?
phox
Old Mar 8, 2004 | 09:33 AM
jrs_dodge_diesel's Avatar
phox
Yes, check the fluid level. That happened in my dads old chevy. A cooler line started leakin good and drained the tranny low enough that the TC didn't have enough fluid to drive the gears. We were driving along and the tranny kicked itself into neutral.
Old Mar 9, 2004 | 09:08 PM
rhills's Avatar
Sounds like a leaky seal fluid just seeping buy . probably around the pump.
Old Mar 10, 2004 | 05:38 PM
DaBigDawg's Avatar
I have a 95 with 167K miles and noticed the tranny starting to leak from the filler tube. Gasket went bad.
Old Mar 11, 2004 | 07:38 AM
Txwelder's Avatar
I had a filler tube break off where the tab bolts up. It broke in half right there and the T handle on the dipstick fell on the turbo and melted. Made a mess and a horrible smell.
Black Dog
Dec 3, 2009 08:18 PM
high bid
Aug 2, 2007 06:08 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
mikie1234
Dec 25, 2004 12:54 AM
silverram323
24
Nov 9, 2003 07:48 PM
