t-case linkage adjustment
I think someting may be wrong......
Stuck at work......... When in 2hi frt drive line spins freely. When in neutral frt driveline will not spin, it moves a little but also moves rear drive line. I thought the frt drive line would spin freely in neutral AND in 2hi. DO i need to adjust the linkage? Alldata says that 2nd position from full forward is 2hi but on my shift knob that shows it would be neutral. I'm confused and stuck......... Any ideas, thanks |
try putting it in 4lo and see what happens if its out of setting then it shouldnt go into. think neutral puts the drive system in nuetral not the driveshafts
It would always go into 4l or 4h but there was some binding in 4h while driving.
I think I got it, its better than before meaning I understand now that frt drive line will not turn because I have that vaccume thing on the frt axle. It shifts into 4h much easier w/ no binding. I hope I got it right. |
