-   HELP! (https://www.dieseltruckresource.com/forums/help-97/)
-   -   Starting (https://www.dieseltruckresource.com/forums/help-97/starting-117827/)
Elk_Hunter Sep 26, 2006 10:52 AM
Starting
I have an 06 Big Horn with 14,000 miles. Just bought it last week.
I just noticed the "Wait to start" sign is not coming on in the instrument panel. If I wait about 7 seconds to start the truck it just cranks and doesn't start. I have to turn it off, wait about 30 seconds, and then not let it sit more than 3 seconds with the key pre-engaged before starting.
Any ideas or is this a common problem?
I have an appointment Thursday to take it into the dealer. Thank goodness for Warranty!!
XLR8R Sep 26, 2006 04:03 PM
The lift pump will only cycle on for 3 seconds when the key is first turned to "on"
Does it start OK if you turn the key to "start" right away?
Elk_Hunter Sep 27, 2006 09:57 AM
I haven't tried starting right away because I always thought that was hard on diesels? This is my first one. I know with my buddy's FORD he lets the glow plugs warm for almost a minute before turning it over.
XLR8R Sep 27, 2006 12:08 PM
cummins don't use glow plugs, but they do have grid heaters for the intake air that usually aren't needed above freezing, though they will certainly cycle above that
unlike F**ds, the Cummins is made to start right away! [guitar]
