Replaced lift pump..still 0 fuel pressure
Old Sep 7, 2006 | 03:25 PM
Black Cloud's Avatar
My truck died while going down the highway, first it sputtered so I turned the Comp off and it acted normal until about a 1/2 mile later when I stopped at a light then it died. I tried crancking it but watched the fuel pressure drop to zero.
Towed it home, and replaced the lift pump today and there is still 0 fuel pressure on the gauge. It acts like it wants to move to 1. The pump is buzzing, all the lines and hoses look good, replaced the fuel filter, there is fuel in the tank...so what gives? Any help gang will be appreciated.
James
Old Sep 7, 2006 | 03:30 PM
Geico266's Avatar
You might me getting air in the system from somewhere. Maybe a broken pickup tube?
I have heard of LP's bad out of the box too. Bench test the old one and see if you can get it to pump fuel.
Old Sep 7, 2006 | 03:42 PM
The lift pump I replaced was only a month old. I imagine you have to drop the tank to check the pickup tube?
Old Sep 7, 2006 | 04:04 PM
Geico266's Avatar
or lift the bed up on one side.
Old Sep 7, 2006 | 08:47 PM
XLR8R's Avatar
Two lift pumps in one month?
Better find out what the root cause is...
Old Sep 7, 2006 | 08:53 PM
If its even the lift pump. There must be some kind of restriciton in the tank itself.
Old Sep 7, 2006 | 09:07 PM
XLR8R's Avatar
Exactly... that's what I mean!
Old Sep 8, 2006 | 05:15 PM
Ok...I took the inlet side hose of off the lift pump and fuel was coming through. I cycled the pump and bumped the starter about 5 times and the fuel pressure slowly rose with each bump until it reached 12-14 psi, so I tried to start it but the pressure once again dropped to zero before settling on 2psi now. What in the world happened with that?
Old Sep 8, 2006 | 05:22 PM
XLR8R's Avatar
Crack the fuel line between the filter and IP and see if there's adequate flow.
Old Sep 8, 2006 | 05:23 PM
Geico266's Avatar
When you go to start the truck the FP will drop to zero. After it starts it should go to normal.
Old Sep 10, 2006 | 10:05 AM
dieselbeef's Avatar
Muted User
open the filter drain and then bump the key to get the lp running. as soon as its real goo shut the drain. then bump it agina dn when the press starts to come up crank it with the pedal on the mat. it oughtta fire then. mine does that after a filter change or running outta fuel.
Old Sep 10, 2006 | 03:14 PM
XLR8R's Avatar
Have you run out of fuel often?
Tedonlin150
Aug 9, 2008 04:27 AM
89dieselkong
Dec 18, 2007 11:38 PM
kd5wqk
Nov 3, 2003 02:06 PM
