-   HELP! (https://www.dieseltruckresource.com/forums/help-97/)
-   -   Rebuilding pump tommorow,wich upgrades? (https://www.dieseltruckresource.com/forums/help-97/rebuilding-pump-tommorow-wich-upgrades-45146/)
redhornet May 27, 2004 10:38 PM
I'm bringing the truck in tommorow to have the ve pump rebuilt,I plan to build this rig to aprox 225 hp through the diferent modes spoken about on this forum.
I plan to ask the rebuilder to time the pump at 15* when he reinstalls it,Is there anything else I should ask for as far as how much he turns the pump up etc?
I just cannot sacrifice fuel milage
next stage is the 16cm housing.anybody got on in alberta?
thanx
1992 d-250 4x4 club Bone stock..............so far.
Lil Dog May 27, 2004 11:10 PM
Turning the pump up is not hard to do yourself as long as you have the instrumentation to monitor what you are doing.
I know this is late, but there is a higher output pump available that used to be offered at most performance shops. I don't know if they have them around anymore.
Getting to 225 Hp is not hard. Heck, with late timing (like 1°)and only moderate pump adjustments to my 93 I hit the rollers at 200 hp at the wheels. I never did do a good dyno run with the timing set and the rest of the modifications to the truck before I sold it.. D'oh..
What shop did you decide on?
J-eh
redhornet May 28, 2004 01:31 AM
I decided on "Camrose diesel injection",I spoke to several local shops that use them,they sounded fine.....we'll see.
Ya figure 15* is o.k to have them set the pump timing?I dont want to stress this engine any,or comprimize the milage.
I wish I had my instrimentation pod set up already just to see what the changes would be from current timing to 15*,but I need the truck,and the pump is shot,so I have to get it fixed now,and unfortunatly I'm to busy to get the guages and install them.
later........john
Lil Dog May 28, 2004 10:50 AM
I hear ya on the busy front.. 15° sounds OK.. Having advanced timing alters your power a bit by giving you more top end power and skimming some of the low end torque, with standard settings.;) Once you get into setting the starwheel, AFC cone etc, you can take care of that low end problem pretty quick.. The upgrade to a 16cm is a good start. I ran a 12cm on mine and loved it.
If you need help with the gauges, I'm not far out..:cool:
J-eh
wannadiesel May 28, 2004 03:09 PM
Have them put in a 3200 RPM governor spring while they're in there.
