pump shaft twisted off
93 w250 twisted off the injector pump shaft last weekend. Does anybody know why this happened. I'm stranded in Baton Rouge , LA. Pump rebuild should be done tomorrow so I can get it reinstalled. I just don't want to put it on and have it happen all over again. Fuel was turned up 1 turn from stock with no star whhel adjustments done. I had had a problem a couple of times with it not wanting to kill. I don't know if this was related or not. 297K on truck but less than 20K on the pump when this happened. Thanks for your help.
The pump might have siezed on some trash left over from the last rebuild. There was probably a chunk floating around by the shut off solenoid which was why it wouldn't shut down. Or something just broke and got stuck. There's nothing internal to the engine that would twist off the pump shaft, it had to be a fault within the pump.
something jambed the pump. i would like to see what they find when its apart. are they warranting the pump?
Do you have any help on making sure I get the pump back in time. Can the gear move in the front housing or can I be reasonably sure that its Ok. Any tips appreciated.
no warranty on the pump after 90 days.
Originally posted by farmernate Do you have any help on making sure I get the pump back in time. Can the gear move in the front housing or can I be reasonably sure that its Ok. Any tips appreciated. |
There is still the stub of shaft in the gear. I've got to dig my puller out tomorrow to get it pulled. I don't have the engine set at TDC yet. All I did was remove the pump to get the shop started working on it. I'm glad to know that it shouldn't have jumped a tooth. I was very concerned that I was going to need to pull the timing cover and that's a tough job for a beside the road mechanic.
If the keyway is at the top once you're set at TDC on #1 you should be OK. When everything stopped suddenly in there God knows what happened. Good luck to you.
I loosened the top bolts on the timing cover and took a peak at the gear. No visible Damage to it. I'm sure praying that there is nothing else wrong. I'm desperate to get this thing going so I can get back to work.
pump went on ok. everything is running great. Thanks for the help.
Glad to hear it worked out OK.
