Pro Comp tire pressure?
I just got a set of pro copmp Extreme AT 33/12.50- 17 and im trying to figure out what pressure to run in them.....They are an E rated tire with a max 3195lbs at 65 psi. My truck is an 03 2500 HO Quad Cab short bed with a weight of 7750 empty. I cant find a phone number to call Pro Comp. Any help would be greatly appreciated.
For the best milage and tire wear, I would run the pressure that is on the tire
DO you mean the max pressure of 65psi?
The pressure on the tire is what is recommended by the manufacturer. I run 65 up front because of the weight and 60 in the rear unless I am towing and then I bring it up to 65. I run about 12 PSI in the sand.
atch |
