Please Help me. My first Diesel not happy
and just wanted to say this a month ago i did have 2 codes 1 or 123 cylinder shut down and 456 code for cylinder shut down never happened again after that but truck still ran great. till all this now. Is there a doctor in the house lol
If a programmer such as the Edge has been added, you may have to go after them for assistance, since D-C can't be laible for what damages may have been caused from running thier programmer. And just like your personal computer keep a tally of every website you visit, your truck's computer keeps a tally of what's gone through it as well. The sad truth is, something's likely been damamged, and now it's going to have to be resolved.
How do u check to see if the waste gate is working properly.
also for the clutch. When i have the edge with juice in the truck and put it on where it enables any back down and put it on with the gauge showing cluth slipping it slips 2 to 4 % max only on roll ons. from a dead stop drop the cluth in second gear and just go it doesnt show any slipping what so ever. i would think that is when she would slip but she doesnt. but with the edge out of the truck the slipping seems not to be there and never feel any slipping wouldnt the dealer have told me if the cluth was slipping god i am so lost on this.
if u have a boost gauge you should be able to see what your boost is. it should be over 30lbs up to 40lbs under acceleration with the edge turned up. you might have a boost leak if not. check all your boost hoses. also is your intercooler aluminum or plastic?
the truck just feels like its flat and doesnt pull like it use too. and i am not sure if 2 aor 4 % clutch slip is bad it doesnt do that unless im rooling on at speed and punch it. if off the line the clutch never shows any slip
it doesnt sound like the clutch and an edge juice on my truck would not slip the stock clutch either. if you are geeting no smoke with the juice turned up and you did before i would guess maybee the juice is not working properly. can you get your hands on another chip and try that.
this is all so weird i had a 2 now this is the second one from them. but even with the juice out of the truck now it seems slow and doesnt pull as hard in 6 th gear at 50 to 90 its like it takes awhile to get past 70 anymore and this is with out the juice hooked up the thruck just seems not as torque monster it was stock even grrrrr i am so lost
also is it normal from 2 to 4 % slip showing on the computer screen when i have all back downs disabled on the juice like it allows for as many min as u put in. but it only shows slipping under load like in 5 or 6 th gear and just roll on it hard. from a dead stop dump the cluth and it doesnt slip on bit anytime.not at all lol
