please help
As normal, I dont have the skills to help. Hopefully one of the "wizards" will chime in. If not, you may want to start a new post in the 3rd Gen Engine and Drivetrain -> 2003-2007 section because thats an interesting problem.
I have no (major) issues with Autozone, but the last time I had an alternator tested at our local store, it tested fine, when it was actually burnt up. Even after the test, I felt the alternator was suspect, so I took it to a rebuild shop. Toasted. I don't completely trust the testing equipment, at least at ours. That being the case, regardless what the machine says, 7 years old batteries are always suspect. Glad to hear that you have the problem solved. It is always nice when it turns out to be the simpler solution.
MoparRiggan
Jan 17, 2006 12:43 PM
