P0192
Hey yall truck in sig. I have had a Edge Hot Juice or w/e unlock'd on the truck for a while and the other day i put on a Quadzilla Rail Pressure Gauge and now my truck is tryin to die and running real rough and throwing a P0192 code i have unplugged the rail pressure and it stop for a couple mins and now the check engine light is back and its doing the same as it was. What could it be? I fixin to take the Edge box completely off and see what happens. \
TIA Sean |
Your LP has left the building. Actual Code: Fuel Pressure Sensor too Low
But it says Fuel rail pressure sensor voltage too low.
Rail Pressure code is P0191, Fuel Pressure is P0192
P0192 "Fuel Rail Pressure Sensor Voltage Too Low
I dont see anything other than that coming up for that code |
The computer fault codes located in the Articles link shows that the
P0191 code is Rail Pressure and the P0192 as the Fuel Pressure Sensor Voltage too low. I'm just going off of the link posted in the Articles sectionv says |
Both codes relate to the fuel pressure sensor seeing low pressure-pos inj,overflow valve,lp,del tube torque,plugged ff etc.Try removing the edge box first & you can ck the overflow valve by loosening the the fitting on top & watching for fuel to leak out(at idle only)-there should be no return flow.
ok so check that and if there is over flow then what?
Then you need a new fuel rail
and what if it doesnt then what does it mean
The other possible items (other than del tube torque & lp pressure)will require some special tools & diag scanner to figure out
A Cummins Tech Advice
Originally Posted by sweeney186
(Post 1911683)
Thank you for clearing that up. I just gave up on this page lol BigTX i havent heard anything from QUAD yet but as soon as i do ill let you know. Let me know ifyou had heard anything yet.
Yep just had my truck in last week for this same thing. They had to replace the fuel preasure sensor. It tested bad. Not sure were this thing is located at but would like to know.
Not sure I understand how a modual would be the cause of a failer. Yes I do have a Quad. Mod. on. My truck just up and wouldn't stay running 5 minutes after I started it and there you have. |
It sounds like you’re experiencing a persistent P0192 code indicating low fuel rail pressure sensor voltage, which is affecting your truck’s performance. Given your setup with the Edge Hot Juice and the Quadzilla Rail Pressure Gauge, it’s possible that these aftermarket components are causing or exacerbating the issue. To troubleshoot, start by removing the Edge box and see if the problem persists. If it does, check the wiring and connections for the fuel rail pressure sensor, as loose or damaged wires can lead to low voltage readings. Also, inspect the sensor itself, as it might need replacing. Additionally, ensure there are no leaks in the fuel rail or issues with the lift pump, as these can also cause low pressure readings. If you’re still having trouble, it might be helpful to consult a professional with the right diagnostic tools to pinpoint the exact cause.
| All times are GMT -5. The time now is 01:25 AM. |
