P 1694
Old Jan 5, 2009 | 10:49 AM
darrenw's Avatar
P 1694
I got alittle problem, the TC keeps unlocking/locking while driving down the road and the volt gauge is alittle higher than normal. I all ready have foil behind the alt. and both batteries are reading 12.66(driver side) and 12.78. I cleaned all of the grounds I could see a couple of months ago.I also have a code of 1694, any help thanks!
Old Jan 5, 2009 | 11:21 AM
darrenw's Avatar
I forgot that the fuel psi is good 16 idle, 11 crusing, and another vp44 13 months ago, i just hope its the alternator or the batteries.
Old Jan 6, 2009 | 11:03 PM
dozer12216's Avatar
It sounds like RFI may be involved. Add a old ignition condenser to the alt output terminal.and ground to alt case. It is another way to control RFI in addition to alum foil around wiring. Won't take long to try.
Old Jan 7, 2009 | 07:58 AM
high bid's Avatar
I know you stated the batt grounds were clean, make sure they are good and tight. A loose ground will cause this.
GMFRB
Jul 28, 2012 08:54 PM
bobem12
Apr 20, 2008 08:32 PM
Sea01Cummer
Sep 24, 2006 05:51 PM
