no start
no start
driving home from work today i left a red light kinda hard when i let off my truck died and now will not start. anybody got any ideas. i have cracked open injectors 1,345, and only getting good fuel flow from number 3. Thanks for any help.i have a 98.5 24 v auto. with tst power max3
I have to ask, are you sure there is plenty of fuel in the tank, not going by the fuel gauge. You said #3 was the only one clean, are the others foamy? If you have plenty of fuel, and the other injectors are foamy, then you will need to bleed the system. You may have an air leak between the fuel tank and the pump. Add 5 gallons of fuel to your tank first, then try to bleed the non-clean injectors.
That's pretty much the standard scenario.
"I left a red light kinda hard when I let off my truck died and now will not start."
Many an Injection Pump has gone Toes Up just like that with a fueling box installed.
Why Injection Pumps Fail
CoolumConst
Oct 11, 2008 10:00 PM
bfarrell
Nov 30, 2005 03:23 PM
502502
Nov 27, 2004 09:15 PM
