No fuel pressure,,,FASS and code 248
I just made it home from a 2,000 mile trip. The trip down was fine, except for one time when I left off the gas too fast under heavy load, and the turbo popped really loud. It sounded like a tire blew. But the truck ran fine.Then this morning when I started the truck, I noticed the fp was down from 20.5 to about 19. Took off, and all day it slowly kept dropping. I drained the water seperator on the FASS and the factory filter. No help. Once it got below 5 I was really getting nervouis. The last 50 mile's, I thought I was only getting 2 psi, but when I got home and looked again, it was actually 0 psi. My light has been flickering for awhile now, and tonight when I really needed it, it was gone. :rolleyes: I was towing a 1 car trailer, loaded, and it felt like the truck was really laboring. I could tell it just wasn't running right. Fuel milage dropped 5 mpg at one point. I stopped at every truck stop and diesel supply house the last 500 mile's trying to find a filter, but no luck. [verymad] I'm hoping Schied just gave me the wrong number on the phone. You guy's think it's just the filter, or could it be someting else. Ever since I installed the Fass, it has made a weird sound. It sound's like a juice harp being flicked about every 15 second's or so. But I thought this was normal. I think it's air/fuel going to the return. Is that normal.
I got a code P0248 ,,, Turbocharger Wastegate Solenoid B Range/Performance . I hope I didn't do any permenant damage when I popped the turbo. So you guy's got any input. Thank's. EDIT: No wonder I couldn't find a filter. Scheid told me FF5588, and FS1001. I just found my filter cross referance list and those number's are not on there. [verymad] |
Check all the intake/intercooler boots.
That loud pop you heard might have been one of the coming off. That would give you a low boost condition. Have you been seeing more smoke than usual? |
Sound's like it's not a lack of boost for sure. ;)
No slam intended, but I though FASS was the "Holy Grail" of fuel systems. It definately sounds like it's fuel feed related by your indicated fuel pressures. Is the turbo still spinning freely? |
No slam taken. :p I was just a sheep following the herd. Thought I was buying the best. I'm hoping it's just a filter. If that's case, it did what it's supposed to. Just seem's like I would have gotton more than 2,500 mile's out of it. :rolleyes: If that fix's it, guess I'll have to polish that holey grail. [laugh]
The lower the fp dropped, the harder the truck would have to work, and I would get a slow, minor increase in boost. Normally while cruising at 65, I would get about 5#'s,,,now it's about 12#'s. Well I'm going out to play in the cold. :rolleyes: |
Have you called the person you got the FASS from? Maybe they have some ideas. Also I would try calling FASS direct to sell what they say. These pumps do have a warranty on them.
Well, I thought I had it fixed. Put the new filter on and I had 23 psi. That's more than I ever had. Went for a drive, and the same thing. Slowly dropped. Hit 0, but has came back up to 5. The fuel was pretty thick when I changed the filter. I think I might run some 911 through it. I can't get a hold of the place where I bought it.
Thick as in gelled, or thick as in contaminated with alge?
Thick as in gelled. I was running the ps/mmm mix about every other tank.
I just ran the tank down until I thought I was going to run out, then put 3/4 bottle of the white PS in there. No change. I'm starting to think my gauge or isolator might be bad. How would I test them. Or maybe the fass just isn't pumping much fuel. Would the truck even run on 0 psi. :confused: |
Well I think I have it fixed. After doing the 5 gal bucket test, I determened it was not the Fass. I took the line off the isolator and blew in it. I got about 2 psi. I'm not a blow hard, so that told me at least the gauge was moving. :p [laugh] I tried to take the isolator apart, but I couldn't get the half's seperated. I thought maybe it was stuck , or froze, or something, so I hit on it with a wrench. :o Put it all back together and now I have 24 psi. I don't think that correct, but I'll start a new post on that.
Do yourself a favor and get rid of the isolator. Then you won't have to worry about it. Isolators are know to give people problems. I started out with one but got rid of it.
I just ran the tank down until I thought I was going to run out, then put 3/4 bottle of the white PS in there. No change. I'm starting to think my gauge or isolator might be bad. How would I test them. Or maybe the fass just isn't pumping much fuel. Would the truck even run on 0 psi. :confused: Did you get the Isolator from Scheid in Effingham? |
