New Steering Box
Old Jul 8, 2006 | 07:42 PM
West Coast's Avatar
New Steering Box
I am going to install a new steering box and steering stabilizer tonight. Is there anything special I need to know with installation?
Thanks....
Dave
Old Jul 8, 2006 | 07:48 PM
West Coast's Avatar
tear down
Also on the steering rag joint where the steering box bolts to the steering shaft I can see one bolt. Is there more than one bolt? How does the rag joint seperate?
Dave
Old Jul 8, 2006 | 09:34 PM
J BODY's Avatar
One bolt. The "u joint" is splined on to the box. Put a bungee cord on the steering wheel. That will insure that you don't "scramble" you're clock spring.
Old Jul 8, 2006 | 11:50 PM
West Coast's Avatar
what the???
New PSC box and steering brace. I did not tie the steering wheel down.... Read the reply to my first post after I installed everything....
And now after the install it will not turn??? Well it will turn but it is like turning a Mack truck with no power steering? What did I do wrong?!?!?!?!?
Dave
Old Jul 8, 2006 | 11:56 PM
West Coast's Avatar
Prime??
Was I supposed to prime the system? If so, what is the procedure??
Dave
Old Jul 9, 2006 | 09:50 AM
West Coast's Avatar
Ok
Someone out their must have had the same issue I have had?
Any suggestions???
Thanks....
Dave
Old Jul 9, 2006 | 10:50 AM
JimmieD's Avatar
This is NOT a Factory Service Manual procedure, but it worked on every other P/S unit I've ever worked on: make sure the P/S fluid is topped up and then turn the wheel all the way to lock on one side, hold for a moment, and then turn to other side to lock and hold, back and forth a few times. This bleeds air out of the P/S pump assembly and lines. Re-check fluid to make sure it's topped up.
Before doing this visually inspect your work again to make sure there's no humbug kind of thing you missed that prevents steering from functioning properly. You can bleed the steering as suggested with the front end jacked up so you don't mine for minerals with your front tires too!
JimmieD
Old Jul 9, 2006 | 01:55 PM
West Coast's Avatar
steering box
Thanks Jimmie. Well after my truck was parked over night the system work fined this morning. I had to top off the power steering fluid and it now works excellent.
Dave
Old Jul 9, 2006 | 02:28 PM
JimmieD's Avatar
That's what we like to hear!
MikeThomas
Feb 19, 2007 10:28 PM
jkap
Oct 23, 2006 04:07 PM
04ctd
Oct 5, 2006 08:27 PM
LanceK
13
Jul 14, 2006 08:08 PM
unioncreek
Jun 29, 2005 02:00 PM
