Need Help on Codes
p2609 code is " Intake air heater system performance"
p0514 code is " battery temp sensor performance/ rationality"
Now these i got for a 2003 model, I dont know if they are the same for your 2005.
Hope this helps.
Allen
Hope this helps.
Allen
a
Thanks,
They may be the same. I ad the batt tem psensir problem when new. Thye tried to clean/dry off but check engine light continued to come on - so they replaced sensor. Maybe it is thge second batt this time???????A
Does anyone have a link to '05 codes?
Not sure about the codes at all. I own a 05 and noticed a had a couple of codes first few days. I checked and they were about the battery but forget the numbers now. I then found out that 'From the factory' the batteries were not really TIGHT in their battery boxes. There is a sensor underneath them and it was getting set off when I went over bumps. I tightened down the batteries really good and not a problem since then. The batteries actually slide around in their box a little. Couldn't believe dealership didn't notice.
Just a thought.
Just a thought.
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
Sam Turner2
Jan 11, 2008 03:32 PM
