Need Another Frame
I'm new to this forum,so I apologize if I am posting in the wrong section.I got into an accident on the weekend and I bent the front passenger frame rail.I have had no luck finding one so far.I have a 93 W250 4x4 extended cab long box,I am looking for a rolling frame for this truck.If you know where I can find one, I would appreciate the help.Thanks in advance.
Hiller65 |
Welcome to the site! Sorry to hear about your problem. You don't say where you are located, that would be helpful.
I have an '89 w250 frame sitting around, not a ex-cab though
Try a wrecking yard with a teletype. Some of the Dodge pickup frames from clear back in the 70's will interchange with the 93 extended cab. A frame shop will have a book on the interchangable versions.
Other than that, these frames are pretty simple to repair. It would have to be really torn up to make it easier to swap the entire assembly than to just put it on a frame rack and straighten it. |
