Missing and Smoking! What the **** happened to my Engine ??
Would a failed injector sound this LOUD though ??? Sounds like a mechanical type of rapping.
Should I go ahead and pull the valve covers off now and inspect the springs/valves or just pull the injectors and have them all tested ???
How does lacquer (have some already) compare to the Techron additive for cleaning/soaking injectors ?
It takes 5 minutes to pull the valve covers and unless the gaskets and o-rings are shot about the same amount of time to reinstall them. Removing the injectors takes much longer and requires new copper gaskets and horseshoe gaskets. I can't believe you have screwed around this long and haven't pulled the covers.
If your injector took a dive, consider it dove and no soak, nor no propaganda like chevron BS will fix it or any other snake oil.
Just lacquer thinner is far superior to any thing else on the planet for getting gumm gum out...go proooove it to your self , no neeed to argue here and you will smile knowing this board LEARNED YOU SOMETHING !!
Everything appears to be OK. The undersides of the valve covers show no markings of something hitting them.
