Mighty Oil Filters made by Purolator?
I just bought a bunch of Mighty oil filters for my cummins because they were cheap in bulk. I was told they are made by Purolator. They have steel webbing on both sides of a paper filter. Cummins recommends Purolator as one of the filters to use on their engine.... since Purolator makes Mighty would this be okay to use you think for a 3,000 mile interval?
Re:Mighty Oil Filters made by Purolator?
TBS 09-004-01 shows the Purolator L45335 as a recommended filter. The question would be if the Mighty filter met the same spec. Suggest you try and get the answer from Purolator. <br><br>Other filters listed were: <br>Mopar<br>Fleetguard LF3894<br> LF3552<br> LF3949<br>Cummins 3937697<br>Motorcraft FL896<br>AC Delco PF1070<br><br>Jerry
