Lightn' strike!
Old Jun 25, 2006 | 06:33 PM
mwireman's Avatar
Exclamation Lightn' strike!
Had a real bad thunderstorm come thru...I'm almost sure that my 1999 dodge 3500 took a hit...gauges all over the place and top speed in 5th gear is 45 mph. I have disconnected the batteries in attempt to reset the computer, but it isn't helping. Is there something else I should try?
Please HELP!
Old Jun 25, 2006 | 07:21 PM
RCW's Avatar
RCW
If you took a direct hit it is likely all your computers are fried. Try disconnecting your batteries and then turning on the light switch to kill the charges that remain in the air bag capacitors. Go have a cold one while you let it just set there and discharge any residual charge.
After about 15 minutes reconnect everything and then start the rig. Let it run about 20 minutes, then if it is not performing and no error codes are popping up, you likely have the PCM, the ECM, and the VP44 all in need of replacement but will not know until you have a dealer or Cummins install a bypass computer connection and look for problems.
Old Jun 25, 2006 | 07:26 PM
mwireman's Avatar
Thanks, I'll try the lights thing and give that a try!
Old Jun 25, 2006 | 10:17 PM
boostjunkie1's Avatar
Remember that Insurance will not cover this= Act of God as they say !
Na-they will/should!
Monty
Nov 8, 2003 02:05 PM
Cowhand
Jun 30, 2003 09:41 PM
Lary Ellis (Top)
Apr 1, 2003 06:31 PM
scottrod
Oct 27, 2002 07:11 PM
