Just replaced front U-Joints ... how do I get the axle splines back in
Hi all,
I just replaced the front U-Joints folling the nice step by step Ball Joint process on the DTR WIKI.
Question: I am now putting it all back together tonight.... how do I get the Differential end axle splines to lift up and engage into the Diff?
I have slid both axles back in the tube but they stop right before the Different spline engagement. Do I need to remove the Diff. cover to lift the end of the axle up?
Also, my Ball Joints look pretty good but both sides have about 1/8" up/down movement on both upper & lowers. How much BJ movement is too much?
Thanks in advance.
***Update*** -after further research I found out that the amount of up/down movement I have on my ball joints is normal. Side to side movement is a problem and indicates wear.
***Update*** OK, I solved my spline problem with a BFH ... I was expecting the shafts to slide in easily and did not want to hit the spindle end and maybe ding it up. Finally I got out the Snap-On BFH and after a few wacks the shaft slide home.
This case is closed!
Thanks in advance.
SN162
10-08-2011 09:41 PM
driftingfly
05-26-2009 10:00 PM
HappyGA
07-25-2006 08:11 PM
