Instrument Failure
I was driving home last night from work without any problems. All of the sudden, the ABS, then Air Bag, Fuel, then Engine idiot lights went off, and then all the instrument needles went to zero. The truck continued to run and I had all instrument lights working. Also the steering wheel controls failed. When I got home, I restarted the truck without incident, but the gauges still failed. What do you think is the cause? Since its night time, I have not had time to check any fuses, but that is where I will start.
Cps
How do I go about finding and replacing the CPS. I believe after reading some postings on DTR, that this maybe my problem (all my instrument gauges failed when the engine was running). 2001 Dodge Ram SLT Cummings...
?CPS/instrument Failure
In addition to my questions posted, I failed to report that on the mileage indicator, it was reading no buS. Is this a CPS problem? 2001 Dodge Ram 2500 SLT Cummings
failed instrument cluster
code 7,
i experienced the exact same problem last spring. i have an 2001 ho 6-speed. i went to the dealer and they said the cluster had lost communication with the powertrain control module. also had no bus on odometer. i checked all fuses and had autozone look at trouble codes. there were two codes they could not identify and said it would take factory equipment to explain. i thought i might have a loose connection and moved wiring at connectors under dash. i took the insturment cluster out thinking i might see a fault in the printed curcuit. when disconnecting the cluster i noticed the gauge needles fall to the stop. i could not see any problem and reinstalled the cluster. when i turned the switch on the gauges jumped up and the idiot lights cycled out. i had a trouble code that when out after 4 normal starts. the only thing that was abnormal was i slipped the rear wheel on wet pavement about 300 feet before the cluster went dead. i thought possibably this might have created a dlitch in the powertrain control module. i have not had this problem again. i bought a haynes repair manual for $17 . it did not address this exact problem, but has provided me with a lot of info about my truck. good luck. i hope your fix will be as easy as mine. randy smith |
Code 7 , i replied to your e-mail ;)
First off welcome to the board (only 4 posts, must be a newbie ;) )
We'll probably need more information about the vehicle in question, assuming it is a Dodge Diesel truck. Year, Model, Make, Color, any mod's that have been done, etc. phox |
You need to check for a wire harnes rub on the dipstick tube. even if its not rubbed through still pull it away. Ive fixed several of them
