Injector Line Problem
I have a question about the injector pump return line On the truck in my sig.
The question I have is , My fuel return line from my VP44 To the T by the back of the head is cracked,, I have an excact same line to replace it with Except the end that the Banjo bolt goes through is Thinner than my line So My banjo Bolt wont fit to long,, My question is are the ends Brazied on or welded on the Line ? I Cleaned it an soldered it for now ,, It is holding, I will try to swap Banjo Bolt fittings Tuesday. Anyone out there done this before? Thanks |
Nobody!!
The question I have is , My fuel return line from my VP44 To the T by the back of the head is cracked,, I have an excact same line to replace it with Except the end that the Banjo bolt goes through is Thinner than my line So My banjo Bolt wont fit to long,, My question is are the ends Brazied on or welded on the Line ? I Cleaned it an soldered it for now ,, It is holding, I will try to swap Banjo Bolt fittings Tuesday. Anyone out there done this before? Thanks I will find out today when I can get to a torch,,, Thanks Will post later. |
