injection pump
injection pump
my truck has been parked because i am waiting on the wheel bearing nut. i started it up just to let it run and got the idea i was going to mess wil the smoke screw. i adjusted it in maybe a turn and a half from where i had it and went to go start the truck and it wouldnt crank over?
i adjusted it back to where i had it or pretty darn close and it still wont crank over. is this just adjustments with the power screw and idle screw? i will try again here in a bit just to see what happens. TIA. i really need to get it running soon though
Messing with the smoke screw will not cause any trouble starting.
It's probably the starter contacts. Try whacking the starter with a hammer with an assistant trying to crank the truck.
i figured it out. i went back and checked everything over it was a wire with a bad connector. (will have to be replaced eventually) but thanks wanna! i didnt think messing with the adjustments would mess up the starting.
tommurray
Feb 23, 2014 10:38 AM
billygoat02
Dec 29, 2005 11:03 PM
adgr71
Nov 28, 2005 07:34 PM
Yukon Dodge
18
Jul 1, 2004 10:08 AM
