-   HELP! (https://www.dieseltruckresource.com/forums/help-97/)
-   -   Ignition Switch wire on '96 2500 (https://www.dieseltruckresource.com/forums/help-97/ignition-switch-wire-96-2500-a-18343/)
D4Fritz Mar 16, 2003 10:50 AM
Can anyone tell me which wire is the Ignition Switch wire on the steering column. I was told that on a 97 it was a light Green and brown, However my '96 does not have a light green and brown wire. Is there an easy way to locate the ignition wire through testing.
redramnc Mar 16, 2003 12:15 PM
Re:Ignition Switch wire on '96 2500
According to the diagram I have it is 12ga DB (dark brown?) from switch to fuse 9 (10A) then 22ga LG-BK to PDC. This is the from Popular Machanics CD for 96 BR2500. Check your PM because I will try to send the screenshot.<br><br>
Smokee Mar 16, 2003 03:55 PM
I just installed the pac-brake on my '94. In the instructions, the years covered would include your 96. The ignition wire is the mid-blue #14 in the harness at the bottom of the steering column. I had to remove the web-like harness to find mine. The wire was in the middle of the bundle. There are several othe blue wires there, but no other #14.<br>george
