Help Turbo question??
Hi All,,, I am in the process of installing my new CTD Over a freind of mines house,,, BUT the turbo from the new engine is in the wrong position,, I know you can clock or turn the Inlet side of the turbo BUT what I am wondering if you can rotate the center ,,What I mean is where the oil feed and oil return line is,,I will have to make a custom return line if it cannot be rotated.. I would like to get it so the feed line and return line are straight up and down..
It is an HX-35 Turbo
HELP
Thanks
Bob
HELP
Thanks
Bob
You can clock the exhaust housing too- there are 4 bolts holding the housing.
You can not change the relative position between oil inlet and oil return.
HTH
AlpineRAM
HTH
AlpineRAM
CumminsRedneck
07-06-2013 03:20 PM
Haulin_in_Dixie
07-21-2003 11:14 AM
redram
12-10-2002 09:54 AM
