help!! truck only starts in morning
I'm trying to remember, I can't off the top of my head, but I believe the fuel cap is pressurized, and there should be some roll over valves on the top of the truck. I have some pics of a second gen tank at the house, I'll look and see.
As far as the fuel foaming, I would try filling a little slower. When does it do it?
Im not sure what you mean about the Roll over value on the top of the truck. It happens everytime I fill the gas tank. I looked at the vent line, no kinks, maybe the plug or stoppage is in the fuel module that lowers into the gas tank. I also noticed that the fuel injection pump has a return line to the gas tank. Maybe the gas cap is not venting and fuel module is plugged inside gas tank..would this cause fuel injection pump to have problems?
Almost the same thing happened to me in my 2000. Would start cold but not once it was warm at all, took a ton of cranking to get it to go.
I found somewhere the coolant temp sensor could give weird readings when going bad and might affect the the computer and starting. It didn't quite make sense to me, but was cheap and I tried it and it worked. Would start much better hot and cold.
ok mine started to do the same thing,1/2 million miles thought lift pump was going out,org pump,had a 4000 mile trip to make and no time to look at cause of problem,pulled trailer ok,would crank till batt. were dead,shot of ether and would it would start right up and run ok. haven,t fixed yet.1999 24 valve both org pumps.
when my lift pump went bad it did that. motor died so i called a tow truck. they finally got to about 3 hours later. when they showed just for giggles i tried to start it and it fired right up and ran for several minutes. must have siphoned some from the tank to start but not run. was in a pinch so just replaced it with an original from Geno's. took less than 1 hour from hood up to hood down
The same thing hapened on my company truck last week after a week in the shop they found out the glow plugs were NFG. They replaced them and its been fine so far but it is a 2010 Ford.
Calgary Roofer
01-03-2008 11:52 PM
nebuniRAM
08-26-2005 03:06 PM
