help...no oil pressure!
If your oil pressure is actually low, pull the housing that holds the oil filter off the side of the engine. You will need to drain your antifreeze to do this, as that is your antifreeze cooled oil cooler under that cover.
Anyway, just about in the middle of the housing once you have it out, you will find an overflow bypass valve. They fail once in a while and are easy to punch out and replace. All Cummins Service Centers carry the valve replacements, and they are very inexpensive.
GlennRMK
May 24, 2007 10:46 PM
Power Ram 250 C
Feb 20, 2007 11:08 AM
QWKRTNU
Oct 24, 2006 08:23 AM
bigragu
Jan 24, 2006 11:16 AM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
