Help need truck on monday at the latest!
Ok so the other day I go to move my 92 w250 5 speed. Jump in turn the key click, try again click craaaaaaannnk just a small week try. Agin click, click, from the little relay or breaker in the fender. So I think battery, load test it; good, jump it; nothing. So then I think let’s jump it with a screwdriver and nothing but an ark from the starter. I pull the starter and all but one brush was sezed and full of junk/brush grit. So I Go to car quest get a new starter, nothing but a click and I think let’s jump it with a skrewdriver and half a turn later it’s running. Shut it off (Manual pull cable) try it from the key and click. Think hmm that relay might be bad I go to car quest I get a new relay nothing but a louder version of the same **** click. WHAT IS WRONG! Help me out I need to pick up a tractor on Monday and I’d like to not have to crawl under there with a screwdriver everywhere I go.
* New starter
*new relay
*starts by jumping w/ screwdriver
Again any help is GREATLY APPRECIATED that click noise has worked it’s way into my nightmares
* New starter
*new relay
Hell yes!!!! Just **** luck you know digging around in my wiring harness fixing chewed off wires I pull up a brown wire and say what the hel l it has a broken end, look at my silinoid and boom I broke the terminal off tightening it onto the new starter. Thank you for your responses!!!
critter getter
32
07-31-2010 11:43 PM
Deuce
11-15-2008 06:40 PM
West Coast
12-11-2007 04:11 PM
tony597fitter
03-05-2007 08:36 AM
