Help fuel pressure all over the place
Old Feb 10, 2008 | 12:03 PM
polarisman's Avatar
I just had a FASS 150 fuel pmup installed. I was reading about 18psi on my fuel pressure gauge and now its really bouncing all over the place. mostly from 12-15 psi and occasionally it will fall to about 6 psi and then the engine starts to cough and miss. Even stalled on me rolling into a stop sign. Engine no cranks about 6-8 seconds before starting when it used to fire in less than a second. Any ideas on why it is doing this??? need some help
Old Feb 10, 2008 | 12:59 PM
RAM2940's Avatar
Possibly a bad electrical connection.
Old Feb 10, 2008 | 07:49 PM
dozer12216's Avatar
Sounds like you have LP pressure while cranking so failure of FASS is not probable. Rotten fuel, water, or filters possible?? Are you where it's really cold and gelling a posibility?
Could you have a vacaum leak? That will make pressure jump around, And you just opened the lines for upgrade.
Old Feb 10, 2008 | 08:01 PM
vzdude's Avatar
DTR's 'Go to Guy'
What kind of a guage do you have? Could be a bad isolator.......seems to be common!
Old Feb 10, 2008 | 08:40 PM
polarisman's Avatar
Have ISSPRO Mechanical gauges. I dont think it can be the gauges as it was running solid before FASS Upgrade. Now tonight when i turn key on i can here fass pump running and guage reads 15 but truck won't start. Just keeps cranking. Anyone have any suggestions? I'm at 1/2 tank of fuel and truck ran good first half tank.
Old Feb 10, 2008 | 08:42 PM
vzdude's Avatar
DTR's 'Go to Guy'
Did you do the draw straw too? Sounds like it is sucking air somewhere......
srt20
Jan 24, 2007 07:49 PM
grantx5
24
Oct 12, 2006 07:27 AM
kowman
Sep 17, 2005 08:37 AM
robert chilton
17
Sep 11, 2005 04:02 PM
bigfoot
Aug 14, 2004 02:22 PM
