Control module gone bad?
Old 03-09-2007, 12:14 AM
973604x4's Avatar
Ok guys get this:
turn key on, all lights come on, sounds normal. As soon as the ABS light goes off, all dash lights come on. Headlight switch is OFF but ALL gauges are lit up. Headlights don't work...nor do the flashers....nor do the brake lights....only the 3rd brake light works. outside temp gauge reads "--"
truck starts fine and runs fine. infact it can spin all 4 wheels. but no headlights or brake lights.....or thermometer.
Old 03-09-2007, 02:11 AM
973604x4's Avatar
BCM failure is the best guess i have.....any other suggestions?
Old 03-09-2007, 03:09 PM
973604x4's Avatar
now truck will only run for a few seconds then dies.
so much for dynoing tommorrow
Old 03-09-2007, 10:25 PM
chop342's Avatar
Location: Climax, MI (between battlecreek and kalamazoo)
i would say from my limited experience with these issues that you have a controller issue of some kind.
Old 03-09-2007, 10:45 PM
Bob Wagner's Avatar
tipm taking a dump ?
Old 03-09-2007, 11:09 PM
973604x4's Avatar
what exactly is that?
now i have 2 codes too...
p0602 ECM Fueling Calibration Error/ECM Internal fault
p2509 P2509-PCM/ECM power input signal intermitent
back in December the cruise control would quit working randomly...but other times work
then SERV 4wd would occassionally come on. Dealer pulled codes....say 2wd, 4hi, and 4low circuits open.
last friday it was eating starter relays....
wednesday lights would come on and off randomly
yesterday all dash lights come on with no other lights
today it only runs for 3 seconds then dies.
HELP.
gooseneck will be here in the morning to load my truck up. its gonna ride a gooseneck trailer to the dyno event
Old 03-09-2007, 11:29 PM
dodgezilla04's Avatar
how about unhooking the batteries for awhile? since most things are controlled by module nowadays, it may be something corrupt and a memory clear might help. just a thought.
Old 03-09-2007, 11:31 PM
973604x4's Avatar
tried that 3 times now
Old 03-09-2007, 11:58 PM
sorry pal, had to check.
Old 03-10-2007, 12:09 AM
973604x4's Avatar
and i appreciate the thoughts.
dealer says what Bob said....
$650 module
Old 03-10-2007, 11:10 AM
Speed Shift's Avatar
Now it wont run!?!
Old 03-10-2007, 09:19 PM
DinosDiesel's Avatar
That Sucks Sorry to hear that phil.
Old 03-10-2007, 10:01 PM
Totallyrad's Avatar
If you think it's the main ECM, check your aftermarket sources before you go to the dealer. I've purchesed 1st gen ECM's from AutoZone and AdvanceAuto.
Old 03-10-2007, 10:10 PM
973604x4's Avatar
I don't think so.
Bullydog was stumped when i called them....but ofcourse they would be.
main ECM is fine, i can still retrieve codes from it....even load and unload bullydog. theres just communication errors between the ECM and something else.
dealer said what Bob said....tipm
Old 03-10-2007, 10:22 PM
DrDiesel's Avatar
Wink
You have a ground issue. Or should I say a lack of ground issue...
Quick Reply: Control module gone bad?
