gear box seal changed, now grabby
Old Sep 3, 2006 | 01:19 PM
laker's Avatar
I replace the upper seal kit by the pitman shaft in my truck. I've taken it for a test drive and found that the steering is sticky. Seems like when the steering is in motion it's smooth but when I go to turn it grabs or sticks. Definately not like it was before. Also the gear box seems quite hot but not the lines to the pump and resevoir? Any ideas on what I screwed up?
cheers
j
Old Sep 3, 2006 | 02:08 PM
XLR8R's Avatar
So you disassembled the steering gearbox to replace the leaking seal?
Sounds like you need to go back readjust it during assembly.
Old Sep 3, 2006 | 05:41 PM
Mexstan's Avatar
Agreed. Check the adjustment. Some steering boxes have two adjustments. Be careful you don't adjust them too tight.
Old Sep 3, 2006 | 10:26 PM
laker's Avatar
That's exactly what I did, thanks for the help,.
jw
Old Sep 3, 2006 | 11:47 PM
XLR8R's Avatar
You're welcome - glad ya got it.
deanhinsley1963
May 5, 2013 11:32 PM
Super Dave
Apr 24, 2012 09:20 AM
Common
Apr 14, 2009 09:18 PM
1tondodge
Dec 27, 2007 06:27 PM
rockittboy
Jan 1, 2006 10:56 PM
