fuel pump problem
Old Mar 3, 2007 | 08:35 PM
jayco's Avatar
Unhappy fuel pump problem
Can anyone tell me how to bleed the high pressure fuel pump? I believe I run it out of fuel. I have changed the lift pump and I am geting fuel to the return line ,but no fuel to the injecters.
Old Mar 3, 2007 | 08:47 PM
Geico266's Avatar
Welcome to DTR
What year truck do you have?
Old Mar 3, 2007 | 08:56 PM
dodge 3's Avatar
You indicated you changed the lift pump, what was the initial problem? My 03' keeps dying and the local Advance store read a code that was "fuel pump A circuit control low CODE:PO628. Was yours a similar problem or code for the pump change?
Old Mar 3, 2007 | 09:08 PM
jayco's Avatar
fuel pump problem
I had four codes po336 crankshaft position sensor A circuit range or performance problem. po253 injection pump metering control A low fuel injection pumpfuel valve open circuit. p1689 and 1688 don't know what those are. I'm sure it not good
Old Mar 3, 2007 | 09:14 PM
jayco's Avatar
I may hve done the reply wrong I am new at this. my code was po253 injection pump metering control A low fuel injection pump fuelvalve open circuit.
Old Mar 3, 2007 | 09:16 PM
dodge 3's Avatar
Yea I had the crankshaft position sensor code first & replaced it. Now I'm getting this PO628. I did find out that the same sensor is used for both the crank & cam.
Old Mar 3, 2007 | 09:22 PM
dodge 3's Avatar
I've got a scheduled appointment with the local dealership Monday if I cant fix it between now & then. If it is a pump circuit problem would that be covered under warranty on the Cummins 100,000 mile part or not??
jayco's Avatar
Mines a 00 3500 with 142,00 its been a great truck until now I hope I don't have to replace the high pressure pump.
Old Mar 3, 2007 | 09:24 PM
jayco's Avatar
thats a good question. is it part of the drive train in there book?
Old Mar 3, 2007 | 09:27 PM
dodge 3's Avatar
OK, that may be part of the difference in the code #s but similar (kinda sorta). Mine has just turned over 90,000.
Old Mar 3, 2007 | 09:28 PM
jayco's Avatar
its a 00 3500 4x4 with 142,000 laramie pkg
Old Mar 3, 2007 | 09:31 PM
dodge 3's Avatar
I sure hope so...
Old Mar 3, 2007 | 09:33 PM
dodge 3's Avatar
What brand of lift pump did you get?
Stevie G
13
Aug 4, 2006 10:27 PM
callum
Nov 21, 2004 07:04 PM
Commatoze
19
Aug 8, 2004 09:57 PM
pro puller
Sep 2, 2003 01:19 PM
