Fuel Problem Help
Fuel Problem Help
Hi everyones,
It looks like I got some kind of leak under the fuel pump it is dripping on the vacuum pump in the junction with the power stering and the truck is getting harder to start after sitting for a wile anyones of you got similar problem before because I can not find exactly where the leak is occuring.
Thanks
Buzzman
Thanks
Buzzman
Has any work been done on the fuel system lately?
I would double check your banjo bolt washers.
The reason it is hard starting is because of the leak.
good luck
Wade
good luck
Wade
I had the same thing on a 96 ctd, was told by dealer it was a designed in hole in the fuel pump to let you know the pump was about to die... Don't know to this day if I believe him, but a new pump did improve mileage, power, and no more leak. Don'y know if it is the same thing you have, but worth a check?
Good luck,
Dennis
Good luck,
Dennis
moparsupremist
08-22-2005 12:06 AM
callum
11-21-2004 07:04 PM
