Fuel in Oil
Fuel in Oil
I have fuel getting into the crankcase when parked downhill. Not when it is running. The injection pump seal has been replaced. And the transfer pump is electric. Has anyone had this problem? It will leak up to 2 quarts over night into the oil. 2000 2wd 2500.
Fuel in Oil finally fixed
The customer finally brought it in. I put 4 PSI to the fuel tank and #3 injector bubbled at the seal with valve cover off. I change all the seals in all 6 injectors. Problem solved.
GlennRMK
May 24, 2007 10:46 PM
