fuel line major leak stuck in bfe what 2 use
Old 05-13-2017, 05:49 PM
cutthroatxxx's Avatar
I'm stuck in the middle of nowhere noway home & have a major fuel leak.Coming from a hard line that sits on top of the bellhousing. None of the parts stores have it & I'm wondering what else will work? It has the push lock fitting & I'm wondering if I can cut the hard line & replace it with some rubber line from the parts store? Please help of you can.97 12 valve has the 94-96; style fuel filter& head running to a holley blue electric fuel pump p.o. installed
Old 05-13-2017, 07:11 PM
Admin Team Leader
Lary Ellis (Top)'s Avatar
From what you are saying that is the low pressure line coming from the tank, no reason you can't use fuel line.
Old 05-15-2017, 03:44 PM
John_P's Avatar
It would help if you listed the year of your Dodge CTD Pickup so the members here could help you better.
John_P
JARHEAD
03-23-2012 07:40 AM
Baja
01-29-2008 08:17 PM
rjm022
09-20-2007 02:14 PM
Rob_OBX
08-22-2004 09:15 PM
srowen
11-25-2003 03:55 PM
Quick Reply: fuel line major leak stuck in bfe what 2 use
