Fuel Gelled last Night
Old Feb 5, 2007 | 08:31 AM
Mark Hodowanec's Avatar
Got to -5F or so. Truck started right up. Made it about 2 miles when it started cutting out & then died. I knew right away what it was, so I pulled the fuel filter, poured in 1/2 bottle of 911 & other half in the tank. After waiting five minites, started it up with no problems. Could not believe how good the 911 works. BTW I was down to a 1/4 tank of fuel, which I'm sure did not help. I then Ran the truck for about 10 miles & fueled up.
After fueling up, the truck started spewing fuel out of the fuel filter. I could see where the o-ring was extruded. After pouring in the 911 I just screwed the old filter back in. I only hand tightened the lid. Can the o-rings not be reused? Did it leak because I did not tighten down the fuel filter lid tight enough?
Is the new fuel & 911 that was mixed with the 1/4 tank going to adequately winterize my fuel? It's supposed to get to subzero again tonight & truck is going to be parked outside.
The truck was starting good all of last week at lows down to 10F or so, but the -5 must have gotten to it.
Old Feb 5, 2007 | 09:49 AM
infidel's Avatar
Sounds more like the o-ring wasn't properly seated.
Old Feb 5, 2007 | 10:09 AM
No doubt about that. But why did it stretch to where it did not seat right? Are they really reusable or after they have been in service & you remove the lid, should they be replaced?
Also, I bought another fuel filter to replace the o-ring (did not want to replace teh existing filter as it only had 1000 miles on it). When I replace the filter I now need an o-ring. Anybody know what size/material the o-ring is? Or, can I just replace the filter & leave the old o-ring in?
Old Feb 5, 2007 | 10:15 AM
HeberRam's Avatar
Question
You should replace the fuel filter after any gel condition. The wax is still in the filter media. Also when you bought a new filter, it should have come with a new o-ring. You need to replace the o-ring as well, as you may have streached it or damaged it when you first removed the old filter.
Old Feb 5, 2007 | 11:41 AM
Seems to run OK now - ran it for 20 miles since I cleared up the gelling. Should I replace the filter now or is any of teh wax from gelling redisolved?
Old Feb 5, 2007 | 07:03 PM
kd460's Avatar
If you get the fuel warm enough the wax will melt and you wil be fine. What that temp is, I don't know. Letting the filter sit in warm fuel for a little while should be good enough. I have personally done this with filters that are clogged from gelled biodiesel. It does take a higher temp than the normal gel temp of the fuel, but once it's melted, your good to go. KD
forwardho
Jun 16, 2012 10:56 AM
1STGENFARMBOY
Apr 5, 2010 12:25 PM
06dodge
18
Jun 4, 2007 12:24 PM
NeedMoPower
Sep 7, 2005 08:43 PM
patriot pearl blue
Dec 5, 2002 09:25 PM
