-   HELP! (https://www.dieseltruckresource.com/forums/help-97/)
-   -   erratic shifting and torque converter locking and unlocking AGAIN (https://www.dieseltruckresource.com/forums/help-97/erratic-shifting-torque-converter-locking-unlocking-again-137625/)
dltriolo Feb 17, 2007 11:33 PM
my transmission is acting up again around 35 mph and the torque converter is locking up to soon and is locking and unlocking back and forth back and forth back and forth. i cleaned the batt. terminals and gray connectors and two grounds off the batt to the finder and the problem went away for a few days but now it is back another mechanic said that the tps is not working properly and at first it had low voltage and then at idle and then we test drove it and came back to the shop and then the tps was at .88 volts and would not change when he push the throttle down but the engine was not running the second time when he was checking it. if there was a problem with the tps wouldn't i get a code or dead petal or some type of major sign? could there be another problem causing this? would a tps cause this? how hard are they to clean or adjust or check or replace and dose anyone know a what i should pay for one dodge said $504.oo for just the part but i am seeing other people post that they are only pay about $150.00. i need some help here i am running out of money i just spent about $4000 on other repairs like vp44, transfer pump, ctm
53 willys Feb 18, 2007 12:53 AM
Have you tried this yet?
faulty sensors and parts don't always throw codes...I had my GP sensor and solenoid go out on my 01 and it NEVER threw any codes...even when it would not move and left me on the side of the road it still never threw any codes[duhhh] what a pain
dltriolo Feb 18, 2007 07:04 AM
address is wrong
i cant the link or some thing is wrong what is the http
53 willys Feb 18, 2007 10:08 AM
https://www.dieseltruckresource.com/...n&onlynewfaq=1
try this again
j-fox Feb 18, 2007 11:39 AM
Your truck has electrical noise getting into the computer.
DTT sells a filter that almost everytime cures this.
The cleaned battery terminals was your clue. The filter costs $39.
dieseltrans.com
dltriolo Feb 18, 2007 03:16 PM
yes
Originally Posted by 53 willys (Post 1363950)
already reset the apps i did this at the same time i did the batts. so i dont know what helped but one of the 3 things i did stopped it for a few days
dltriolo Feb 18, 2007 03:20 PM
if the tps was at a constant voltage no matter how far you pushed the accelerator down wouldn't that cause the engine to run at what ever the tps said the throttle was down at? the second time he checked it with his scanner the truck was not running but the key was on wouldn't the tuck have to be running to check the tps voltage on the scanner?
dltriolo Feb 18, 2007 03:27 PM
dose any one know of a link that shows how to check tps i need one with pictures. and how dose the cover come off the top bolt or screw is missing and the front screw on the bottom side will not come out it just keeps turning. i dont want to take a chance breaking it because if the tps is $504.00 the cover probably around $350.00 or more lol just joking but it would not surprise me if it were
53 willys Feb 18, 2007 05:08 PM
1 Attachment(s)
Here is a littile info on the APPS....
The APPS assembly is located at the top-left-front of the engine. A plastic cover is used to cover the assembly. The actual sensor is located behind its mounting bracket.
The Accelerator Pedal Position Sensor (APPS) is a linear potentiometer. It provides the Engine Control Module (ECM) with a DC voltage signal proportional to the angle, or position of the accelerator pedal. In previous model years, this part was known as the Throttle Position Sensor (TPS) .
Diesel engines used in previous model years used a mechanical cable between the accelerator pedal and the TPS lever. Linkage and bellcranks between the TPS cable lever and the fuel injection pump were also used. Although the cable has been retained with the APPS, the linkage and bellcranks between the cable lever and the fuel injection pump are no longer used.
The APPS is serviced (replaced) as one assembly including the lever, brackets and sensor. The APPS is calibrated and permanently positioned to its mounting bracket.
CAUTION: Do not attempt to remove sensor from its mounting bracket as electronic calibration will be destroyed (sensor-to-bracket mounting screws are permanently attached). Two accelerator lever set screws are used to position lever. Do not attempt to alter positions of these set screws as electronic calibration will be destroyed.
dltriolo Feb 18, 2007 06:10 PM
so if it was getting a constant voltage of .88 volts then there would be no response from the gas petal when i pushed it correct? that means the mechanic checking it with the truck not running didn't know what he was doing? what happens if the sensor goes completely out?
dltriolo Feb 18, 2007 06:30 PM
i guess my question is dose the tps entirely control the acceleration of the truck? if my truck is going faster the more i push the gas petal down then the tps is working?
53 willys Feb 18, 2007 06:32 PM
you should have +5vdc at the apps supply..
and the voltage should vary at the signal wire as you push the pedal down.
53 willys Feb 18, 2007 06:33 PM
do you have a multimeter???
dltriolo Feb 18, 2007 06:42 PM
yes
but cant get the cover off the tps the top screw or bolt is missing and the front bottom screw just turns and wont come out how do you get the cover off i dont want to force it. and how do i test with the multimeter?
53 willys Feb 18, 2007 07:31 PM
check it at the plug for voltage... use the pin pic I posted above^^
spot #5 on the plug is the supply wire it should have +5VDC.
Spot #3 is the signal wire and that voltage should vary....
don't unplug the sensor to check it just poke the meter in from the back of the plug to get to the wires.
when you get the meter on the signal wire have some one step on the pedal and see if it changes voltage..I would do this while the truck is running too.
if you have the 5VDC supply but the signal wire never changes then it is a bad APPS I would say......
Clear as mud???
